Sluggish Acceleration under load
Coach Poffy
Georgia
I have a 2005 5.4L with 170,000 miles. engine replaced with rebuilt at 70,000 due to timing chain problems. Bank 1 cat replaced at 120,000. Now have very slow acceleration from stop and on highway around 1900-2000rpm. Checked datalog and O2 12 sensor was bouncing all around from .100-.700. Engine temp 190. O2 22 sensor was steady around .500-.600 with engine at 2000 rpm. Checked temp on cat 1 and input side was 390-410 output was about the same. Checked cat 2 and temp was 390 input/ 530 output. Figured cat 1 was bad. Replaced today at Midas. Vehicle still running with sluggish acceleration around 2000 rpm. Checked datalog again and get similar readings from O2 sensors. Did verify shop welded a cat on bank 1. O2 12 sensor still bouncing around between .100 -.500 amps at 2000rpm and engine temp 190-200. Cleaned MAS (not dirty) Checked Air filter. What do I look at next?
HolidayJones
NC
I have a similar problem in my 2nd gen 03, with the old 2v. But mine is throwing lean codes. Acts like it's getting too much gas under take off
Sent from my HTCONE using Tapatalk
HolidayJones
NC
I can't remember, it's been so long since I had to checked. My check engine light is just a permanent fixture at the moment
