small oil leak in front.
2005Expedition
Jackson
I cant track where this oil leak coming from, it right under the fan belt, and right next to oil filter housing,its wet back there.
here is the pix, it not drip drip, but some time I saw a nice oil spot hang there.
2005Expedition
2005Expedition
Jackson
it not oil leak, its coolant leak, but I dont see it dripping while idle , and I dint note any lost in coolant level.
ExpeditionAndy
Fort Wayne, Indiana
When the water pump seals start to go bad it will start to leak coolant out of a little hole on the bottom of the shaft housing when the system is under pressure. This is an old school heads up that you need to start thinking about a new water pump. It may last several thousand miles like this and only leak when the pressure is very high like on a very hot day when you are stuck in traffic.
2005Expedition
2005Expedition
Jackson
thanks for head up, I am on my 800 miles road trip right now, she ran fine and I check for leak every gas up, but none leak, and it look very dry. I will keep my eyes on it.
