Spare Tire Hub Bore
Page W Sutton
Memphis, Tn
Anyone know the difference in the standard hub bore of a 22 inch wheel vs the larger hub bore of the spare?
Will the bracket for the spare tire fit the smaller hub bore of the 22" wheel?
Black
Kentucky
I highly doubt it. Seems a lot wider when I pulled the spare.
Just drop the spare see if it will fit. You could possibly shave each side of the bracket at the end of the tether so it will fit.
I know the 1st generation Raptors spare wheel is the same as the normal wheel just black. Might be able to swap that bracket to the end of the tether.
16plati
VA
Are you suggesting you are gonna put a 22” OEM style 87.1mm hub bore wheel and tire combo under the truck as a spare?
