Spark Plug Removal without breaking trick
YankeeTR5
washington
I just successfully removed all 8 plugs with none breaking and thought I'd share a tip that I think makes this possible. Sidenote I own several classic cars so am comfortable doing my own work....although I was pretty uncomfortable taking on this job!!
My 06 Expedition has 108K miles and I'm the original owner. I started experiencing a slight miss around 90K and by 105K miles it was bucking pretty regularly at 45 mph under load. So here's what I did and why I think it will solve the problem of breaking plugs:
First, I added a can of Sea Foam fuel system cleaner to a half a tank of gas and went on a long drive. Not sure if this is significant, but since I did it I thought I mention it.
Second, when I got ready to pull the plugs, I warmed up the engine.
Third - and here's what I think made it all possible. I pulled the air filter and SPRAYED 1/2 can of Sea Foam spray into the air intake. I weighted the gas pedal so it was running at 2500 rpm. The engine bogged down a bit, so I had to let it recover and then spray more. I sprayed it directly into the intake and sprayed it side to side so it would get into each of the intake runners. I then shut the engine off.
I'm not a big endorser of products, but I had used Sea Foam spray to de-carbon a 92 BMW M5 engine about 10 years ago, so I was comfortable that it wouldn't affect the catalytic converter nor ruin the rings etc (an M5 rebuild is about $12k....) so I thought it might work here.
All my plugs came out wet. The first 4 (drivers side) had very little, if any, residual carbon, but none built up. The second 4 plugs had far more carbon build up but I had let the motor cool down (took a break to run an errand for the wife for over an hour in 45 degree weather). The carbon was still pliable, but it had transitioned from a wet liquid to more a very pliable clay. So warm engine is highly recommended, if not essential.
So, my takeaways: Sea Foam sprayed into a warm engine penetrates up the length of the plug and loosens (at worst) or dissolves (at best) any carbon built up on the plugs. It seems to work really well on carbon. I used a 3/8 inch breaker bar (when space allowed) and steady pressure and all the plugs came out like any other plug I've removed.
Maybe other products will work...probably will. I know on the M5 forums Sea Foam is specified, so I'll stick with that.
Good luck to all who take on this job themselves and I hope this helps. I checked with two dealers and was quoted over $750 at each place (one at least put a "cap" on the job at 750....whatever). I did have to unbolt and move the ecu on the passenger side firewall to get access to the two rear plugs, but other then that I did not remove anything other then the COP's to get access to the plugs. Car runs great now - way better performance, a bit better mileage too. Total time about 4 hours, but I think I could do it in 2 if I had to do again.
Cheers....Dan
tsingson
NC
I had the tool and it's a good thing I did because I broke 7 of them. I will have to try this method next time. Good job on the write up as well.
2003SLT
Cottage Grove, MN
This is pretty common practice in most shops I've worked in. We would unhook the fuel rail from the tank lines and hook it up to a machine that would supply the correct pump pressure with 1 gallon of gas and 1 pint of a decarbon additive in it and run that through to get the engine hot. Then we would crack all the spark plugs loose, just 1/4 turn or so and spray Seafoam into the spark plug hole so it would get down into the threads. In 12 years I have never broken a Ford spark plug or pulled out threads.
EJohnson
Portsmouth, Va
Okay, so I've been researching changing out these DREADED plugs (probably would NOT have bought this vehicle had I know this before)! I started today at the shop on base and got everything all torn apart but when I went in to get the rear plug, passenger side (??#) the sock would "bottom out" on the plug tip, but seemed as though it was NOT turning it. I took a pic and will insert as soon as I figure out how to get it on here. Basically it looks like a bunch of black rubber around the coil threads. I have NO CLUE what to do from here. Please help!
Lostneye
NY
Look at the removed COP for the cylinder compared to the others. Possibly the boot has torn and a piece is still on the plug.
On the subject I recommend replacing boots/connectors when you do the plugs.
EJohnson
Portsmouth, Va
Silly me!
Okay so, I figured out what it was I was looking at....FLUID! I was attempting to move one of the hoses (silly, I realize now), because it was in my way! Well, I forgot the fact that some of that coolant/water seeped down into the plug hole! Gheesh!
I did get plugs 1-5 out by funneling in some brake cleaner, letting that settle for about 10 minutes each, then taking out with a low-setting impact...worked like a CHARM!!! Then again, the plugs I took out were NOT OEM (champion Platinum)! There was SOME corrosion but not enough to lock them in! Better safe than sorry I guess! Anyways, thanks for the replies guys!:Rock on:
