Al Harper
I have a 1998 Expedition, 4WD 5.4 engine.
2 days ago 4WD lights and others lit up, OD light on shift started blinking, engine check light came on.
Speedometer is reading 0 (zero)
Vehicle only shifts into 1st or 2nd.
DTC = P0500
I'm quite sure the VSS is bad probably.
When searching the web to determine a.) where the sensor is located and b.) the correct part to get, I'm not getting consistent readings from anyone or postings as to where this sensor is. Remember I have a 4WD.
There's discussions about output shaft speed sensors, speed sensors, speed sensors on the differentials, and on and on, with all of these different sensors descriptions and location being used loosely in various discussions.
I feel confident I can do this job myself if I could just get some absolute accurate information.
Thanks ... waiting for THE answer.
Al Harper
P.S. Photo's welcome
DTC = P0500
Al Harper
