sputter but no light
99ebexpedition
louisville
i was picking my mom up from work today and on the way home i was at a light and my truck started to sputter at stops when i first take off and goung up a hill. i was told if its a spark plug the check engine light would come on.
Of course this happen right when i get ready to order my strutmaster kit
2001Expy
MI
Mine does the same thing and also shakes too. I have found that it is caused by bad gas, so I usually ride it out till half a tank and then fill up with shell gas usually. After that it goes away.
tmajikman
Cartersville GA
It could be a cop on the way out, and until it goes out completely, it will not aalways show a code.... I would try new fuel or a new fuel filter first, but cops are known to do that, cops are also known as Coil On Plug, coil being the issue btw.
Reconracer
Gilbert, AZ
My Expy sputtered with no code until I pressed the accelerator to the floor...then the CEL lit. Ended up being a couple of spark plugs; I replaced all of them and the COP's while I was at it. 6 months, no issues.
99ebexpedition
99ebexpedition
louisville
so now the sputter is gone i think it was dirt in my gas i put some lucas fuel treatment in it. but with it doing that i lost my heat again. and then it came back.
i turned off my air ride should i expect to get anny problems since i did.
and has anyone had problems out of there rear wiper. mine wont work and its not a fuse.
