Squealing noise during slow speeds
xbreedjr
Dallas, TX
My 2005 Expedition has been making a new noise lately. When driving at lower speeds (under 20 mph) after driving for about five minutes or so, you’ll notice a constant squealing-type of noise that seems to be coming from under the car. It’s got new brakes and pressing the brake doesn’t alter the noise at all, also just had driveshaft u joints replaced 2k miles ago and trans rebuilt. Also doesn’t change when the wheel is turned/straight. Wondering if it’s maybe a problem with the diff or 4wd vacuum lines?
whtbronco
Winchester, VA
With new rear brakes it could very well be your parking brake. When it's squeaking just set the parking brake 1-3 clicks to see and then release it soon after of course.
GaryH
Army
Check the serpentine belt and all of the idler pulleys. I don't think the belt would squeal unless it's very loose, but the idler pulleys can and do wear out. Also check the belt tensioner.
BlackCoffee
SOMD
I am thinking belts as well, or maybe the tensioner. Far fetched idea, but older cars you find a lot more hard to diagnose problems. May want to check the harmonic balancer. The rubber may have deteriorated a bit, it will slip like the serpentine belt before it fails.
