kyle_in_rure
Hello all,
Around late this past February I took a hard right turn at an intersection and the truck immediately stalled. After that the truck would try to stall every time I tried to come to a stop. I disconnected the battery to reset the computer and everything returned to normal after the idle was relearned (although it seemed like the truck revved a bit more than usual when cranked since then)
All was fine until this past week, I've taken two 100 mile trips back and forth, the truck seemed to do well. Today I was on the highway for about 30 minutes (just got an oil change) and turned onto a back road. I had to take a pretty hard right turn again to dodge someone crossing the center line in a curve, and it Stalled and lost all power while going ~30 miles an hour. then it kept trying to stall when coming to a stop but would eventually hold steady.
I'm going to pull the battery again in the morning before I leave and hope it fixes itself like it did last time. Any idea of what would cause this? It reminds me of how the idle behaves rough after the battery is disconnected, except much worse. It will float around 100-300 RPMs and just die if I don't give it gas. It makes no difference whether the vehicle is in drive or neutral.
I replaced the IAC valve exactly a year ago because it was emitting a loud buzzing noise, so I don't /think/ that's the problem.
Thanks guys.
Thanks guys.
