Start battery finally gave out, what’s the preferred replacement?
Luis Monjaras
Brambleton, VA
I just replaced mine with the same Motorcraft battery a OEM. Bought it from Rock Auto https://www.rockauto.com/en/parts/motorcraft,BAGM94RH7800,battery,2476 and it arrived two days later. First time using that website but I am very pleased so far.
Although you all probably don't need it, I thought this guide was pretty helpful: https://paulstravelpictures.com/201...tomotive-Battery-Replacement-Guide/index.html.
It assure easy to change, all of my settings and clock stayed input - the only thing that I had to change was for some reason my running boards went from "auto" to "off."
What did you do with the old battery? Did Rockauto give you $$$ for the core?
Artie
Artie
Georgia
Thanks for all the replies!
I ended up just having the dealer replace it. The had the vehicle for 10 days for the oil change, front passenger seat moving by itself, a terrible squeak in the front seat, and some weird skipping issues with the transfer case. I just don’t have the will to work on this thing so replacing the battery myself just didn’t sound appealing…I may unload it soon if these small issues don’t go away.
Transfer case issue was not resolved. So far the seats seem to be fine.
Don Hall
SANTA CRUZ, CA
I can't find any battery on Costco.com that would fit the 2019 Expedition.
You are correct. From the Interstate site:
2019 Ford Expedition V6 3.5L Standard​
We're sorry. This battery fit for your vehicle is not currently available at Costco.
You need: Group Size (BCI): 94R
duneslider
Utah
I have used a lot of diff AGM batteries and really am not seeing much difference in life between them all. I have not used a northstar in a long time, very hard to get. Optima, Deka, everstart from walmart, house brand at o'reilys, etc. I just am not seeing a difference in the life between them all. The Ford battery seems just as good as the rest and I wouldn't hesitate to go that route. 4 years doesn't seem bad for how much it is used. If you really cared, I bet you could get another year or two if you put the battery on an AGM specific battery charger once a month. I tested this on one battery and I felt like it really did make a difference. I am not dedicated to do this all the time on all my batteries but I do try to charge them maybe once a quarter.
I don't know the details on the ford charging system but typically car's charging systems are not setup for AGM batteries so they never get a full charge.
Artie
Artie
Georgia
I religiously turn off the ASS so I’m not as hard on the battery as the manufacturer would assume and I have used a charger in the past. I may throw it on the charger if I know I won’t be driving it for a day or so once every few months… not a bad thought.
Zig10
Mid Atlantic
I've seen a huge benefit in my boat for the electronics and recovery ability with AGMs, but this is the first one I've had to replace in a car due to age. Given the running boards, proximity sensors, alarm sensors, etc. that are always energized, I am surprised this one lasted as long as it did, especially since my wife only drives it 10 miles to work.
One thing I noted is that the battery tray looks like it could take a larger model. In hindsight, I probably should have looked into that a little more...
bobward757
Johnson Controls makes Motorcraft's batteries. 4 years for a 4th gen high load / high cycle AGM battery is damn good. The only other AGM battery I'd consider is Deka from Philadelphia. East Penn Battery Company technically. They have their own label (direct ship) but make the Duracell car batteries sold at Sam's Clubs. eastpennmanufacturing.com
Rossue
SLO CA
Another bad battery after 15 months. Would barely crank one time yesterday so trickle charged it overnight. Autozone's tester showed 79% charged and said "Bad Battery". Going in tomorrow for a free one.
Costco has a flooded Group 94R, however no AGM.
Newport News, VA
agm battery for sure...top dogs are nortshtar...xs power and a few more...i put a northstart gp 65 agm in and havent been happier especially being in car audio...i think northstar is #1 but the others are just as good
Rossue
SLO CA
Dealer had me come in this AM without appointment - squeezed me in- and said it turned out to be a loose negative connection at battery. They said they did a full charging diagnostic and everything was now fine. Didn't charge me.
Newport News, VA
still get the northstar G65 agm battery...i left my truck sitting for 5 months with my 30K watt rms system in the truck...battery was 2yrs old...one jump and 20 min drive home later still running that battery today without fail...what other batter can sit for 5 months in our trucks with all my equipment? i still had enough juice to roll down the windows and play music until i got it jumped...5 months no start and nothing disconnected
BaumSquad
Sparks, NV
The Interstate Batteries MTX-49/H8 would be my go to, Costco's version of the Interstate is just as good. Both are made by Clarios, the company that bought out Johnson Controls a few years ago. As far as the two mentioned above from O'Reilly Auto Parts, just on price alone, those look to be flooded batteries, and if your vehicle came with AGM, you are better off to pay the difference and stay with Absorbed Glass Mat.
29twonine
Colorado
I replaced ours with the Autozone Duralast Platinum. Came with 3 year warranty so if it ***** the bed I'll just take it back there. We do lots and lots of short hops to school and back so I'm sure that didn't help it, plus we're in Colorado so the weather doesn't help, either.
5280tunage
colorado
Duracell at Batteries Plus. Made by East Penn Manufacturing or makes Deka.
I just purchased one of these from Sam's Club. Did a lot of research, and a lot of the "better or best" ones out there aren't even available. Did my research and found these were made by East Penn, which has been making automotive batters for around 50 years. Figured they had to be doing something right. As for the price with the warranty, figured it was worth a shot.
Uberexpy
Pennsylvania
My first Motorcraft battery went 6 years. My second Motorcraft battery went 5 1/2 years. I’m on my 3rd Motorcraft one now. They’ve been around $200 to $250 installed. I figure if the OEM lasts that long, why gamble? I’m using the same theory on the brakes. I’m finally getting pads & disks all the way around this Saturday. The original set only has 138k on them. The estimate at the ford quick lane is $900.
ManUpOrShutUp
PA
Well, Weider has been making fitness products since 1936, been sued (and lost) for false advertising on a grand scale numerous times and has been making absolute garbage equipment since at least the 80s - but they're still here 86 years later. A longstanding business is the result of management and marketing, not an indication of a quality product. As for the batteries, it seems like a crapshoot these days. I'm satisfied to get 3 years and if I get more, great.
VBreithaupt
Costco!!!! you can't beat for the price and if you use your Costco Credit card they extend the warranty for free.
Aspen03
Indianapolis
Costco, currently in both our vehicles and I've used then in 4 others over the years without a failure. The price is tough to beat and 3yr replacement warranty is solid.
