Mojave Jack
Help...1997 ed 4x4 5.4 ...196619 miles, 2nd owner since 36k...intermittent problem becoming more frequent...a few months ago I was telling my relatively late 5000 pound travel trailer up the steep grade when the gauges all went bezerk losing oil pressure no voltage no fuel and overheating so I pulled over of course and uh kept it onto keep the fan going but then ended up turning it off and restarting it and the gauges went back to normal just fine. But now my gauges are doing the same thing more often and its even affecting the oil pressure light which I pulled over immediately check the oil and it was low and I added a quart.so as I am driving now the gauges will go to search except for the fuel gauge it'll overheat it'll go to zero voltage and no oil pressure plus the oil pressure light will come on but the fuel gauges find accurate I also will have regular power no additional sounds no problem idling but then eventually it'll go into kind of like a Limp home mode perhaps, so I find that I am putting it in neutral all the time turning up the car while its rolling and then restarting it so that it resets the gauges and gets me out of limp mode anyone have any ideas? oh and I forgot to mention that sometimes when the gauges first act up you can touch the break turn on the blinker and the Volt is dancing or the Volt meter is dancing with the electrical draw. when the gauges on phone turned me into a little pressure to vote me your and the water temperature go bad but without the oil light going on the car drives great and no limp mode is Experienced. any diagnostic impressions would help me out a lot thanks in advance dot dot dot
