rwing21
Hello,
New member here however will be around a lot more thanks to buying a 04 Expedition.
Today I pulled the headliner today due to the amount of water that was leaking down the passenger side A pilar and rear seat belt covers.
Have some questions:
1. I know the rear passenger side drain tube is clogged. I cannot blow air down into the hole by my mouth for sure. (Can on the rear driver side) I tried passing down some weed eater line and it stops quite a ways in, not sure if it is the terminating point or not. The line comes out wet as if water was standing in the line.
Have attempted to use can of computer air to no avail. Any other suggestions?
2. Around the sun roof glass, I can see daylight. I have read a lot online that sun/moon roofs are not 100% leak proof and I get that, hence the drain tubes and drip bar.
However, should I be able to see daylight?
Thanks for the input!
