Swap to F150 bumper/grill
Lightnig
Behind you
Well, not those specific pieces, but yes indeed I've thought about it.
In fact, I've got a F-150 bumper, grille, grill mount, and valance in the back of my truck right now. Just waiting for warmer weather so I clean up the pieces to swap onto my truck...
But then, mine's a Gen 1, so I can't speak to these parts you've posted.
Oefootball_70
Oefootball_70
Olathe, KS
Yeah gen 1's have been done a lot. In fact 96-03 f150's swap 2nd gen expy front ends a lot.
No one seems to have attempted this. I'm thinking about getting a grill of a f150. That would let me know about that much. I hate having a plastic bumper so bad. The f150 bumper powder coated black would be sexy.
jjbusa
miami
The grill is attached to the hood on the f150 isn't it.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Mikes05expy
Toledo, Ohio
My neighbor has an 05 f150 and the grille is attached to the hood. I have also thought about this same swap many times, it would be cool to see somebody do it.
Sent from my Bag Phone using Tapatalk
Oefootball_70
Oefootball_70
Olathe, KS
Well. I'm going to try and figure the grill portion out first, I figured that will be the toughest. I'll keep you all posted.
tallsville
LA
could always switch the entire front end. fenders, hood, grille, bumper. maybe find a rear end wreck in the junk yard. not sure it would work. but if 402motoring can put a 2nd gen front end on a 1st gen. im sure you can make a 04 f150 front end work on a 2nd gen.
Spooky
I want this bumper!!! Could I just switch to an F150 hood and add this bumper or would I have to change out the whole front end?
rydnlow
Ft. Lewis, WA
As stated the grille is attached to the hood so you would also need the hood. Not sure if the headlights are slanted at the same angle either. Probably be better off just doing the whole front. You would end up with better gap alignment.
tallsville
LA
Spooky you can always find a fabricator around you to make one. But if I remember correctly someone on here contacted the manufacture about that bumper and they said they would need a 2nd gen in the shop and use it as a test rig.
Newport News, VA
im not 100% but i was told that the headlights dont bolt up the same either...may need a new shroud
No members online now.
Landsbutter
