The Sandlapper
Just bought first Ford ever yesterday, used 2022 expedition limited. The "kick" feature on the rear door is not working. Is there a setting in the menus that I am not seeing to make this work?
LOL, had same experience with the Suburban. I guess we only remember the bad times. I do miss it, even with the "misfires" that we both have obviously experienced.In five years of ownership I’ve been able to get mine to work when I needed it exactly once. I can’t count the number of times it has closed on my head, though…. You aren’t missing much.
That’s what I was told and that made it the most consistent. Unfortunately because it also registered unintentional movement, when playing around the hitch area, I disabled it by removing the antenna.If the system is inconsistent try using a straight kick under the center of the bumper. Dealer told me side to side movement isn't registered by the sensor. My only struggle is opening the hatch when my hitch is installed.
Straight kick, then a step backwards. That'll do it.If the system is inconsistent try using a straight kick under the center of the bumper. Dealer told me side to side movement isn't registered by the sensor. My only struggle is opening the hatch when my hitch is installed.
I have a 2019 Expedition Platinum. I could rarely get the liftgate to open using the kicking motion. However, every time I hooked up my boat trailer the liftgate would activate and try to hit me in the head. Other times it would start to close when loading stuff into the back. I finally removed the lower antenna from under the rear bumper. I kept the antenna and plan to reinstall it when I sell the vehicle. To plug the open connector, I purchased a used antenna on eBay, cut off the connector and plugged it in to prevent corrosion. What a relief! I can now go fishing without the fear of dodging the liftgate.
