B
bedrck46
BE CAREFUL you may want to disconnect the connector at the transfer case and check to see if your getting full voltage to the shift motor. Also you may want to use extra wire to do this so that your not under the expy then switch into 4H and 4L to check the voltage or pull the shift motor and check it on a bench
make sure you have someone with you and take some jack stands if you pick it yourself.
