Thermostat problems?
Vigilante
San Francisco, CA
So I just installed a new thermostat, and while idling the truck, new thermostat installed, I did not see the temp gauge coming up at all. I plugged in my computer and could see I was operating at 180 degrees and the gauge still read dead cold. The thermostat is installed correct (spring side down). I have no leaks at all, the heater core hoses are both hot and the upper radiator hose is cold.
Any thoughts?
Vigilante
Vigilante
San Francisco, CA
Also, I have a light on the dash on. It seems to tell me there is oil in the coolant. It just shows the oil can adjacent to the water temp symbol. There is no oil in the coolant and no coolant in the oil.
One more thing, I have water in it right now. The truck has been in my garage in storage for the winter and I drained the coolant out for other maintinence and filled it back up with water. Can my problems stem from a lack of coolant in the water?
toms89
technical advisor
MD
Any thoughts?
Air pocket?!
Assume you refilled coolant with motor running initially?
Lightnig
Behind you
did you happen to knock a wire off the water temp sensor?
I have no idea where it would be located on the modular engines, but I know that was an easy thing to do unintentionally on the older 8's...
toms89
technical advisor
MD
Oil can light means low or no oil pressure. Whats the gauge read?? Dont think these have low oil level lights.
Lack of coolant vs water should not cause issues. Until it freezes or boils that is...lol.
Vigilante
Vigilante
San Francisco, CA
Well my garage is warm, so freezing has been no issue. As for water temp sensor, I'm honestly not sure where it's located. Didn't see it when I started doing the job.
It could be an air bubbly. I hate how there is no direct way to fill up the radiator minus removing the hose and filling it up that way. It was pretty bone dry. And I fed it from the hose until the tank was full. Then started the truck, waited a few minutes, topped it again and took it for a drive around the block and didn't see the gauge coming alive so I just went back home.
Lightnig
Behind you
That reminds me of a much needed maintenance procedure required on the old SHO's after refilling the coolant: "Burping" the hoses...
if the system was not completely purged of air, the temp gauges would give really wacky readings: could show completely cold when the system was hot, or way over heated when the temp was normal, or even bounce between completely cold and Surface of the Sun hot...
One those cars, the rad hose was designed in such a way the large air bubbles would get trapped in the upper rad hose. After refilling the rad, one would have to "burp" the system by squeezing the upper hose whilst the car was running. This would force the air through the system and ensure a completely filled and purged coolant system...
Vigilante
Vigilante
San Francisco, CA
Ok, so I tried "burping" the system to get as much air as I could out of the system. I started te truck to get te system flowing and could tell there was fluid in tr upper radiator hose, and I would squeeze it to try an push the air out of the system. But it seemed to all be in vain. I noticed my check engine light on and it came up with these 2 codes
P0118
p1289
118 is thermostat input too high
1289 is cylinder head temp input too high
Could I have faulty sensors or are there still other issues?
Also, I looked at some videos of other 4.6 thermostat install videos and I see people installing it differently. Spring end down, but instead of te gasket around the edge of the thermostat it just sits on top of the thermostat once the thermostat has been set in place. Which was us accurate? Even my Haynes manual doesn't say.
toms89
technical advisor
MD
P0118
p1289
Spring end goes down. O-ring gasket on top.
Vigilante
Vigilante
San Francisco, CA
Ok. Well that's how it's installed. Tomorrow I'm going back to the auto parts store and swap out the thermostat for a new one.
Temple, Georgia
Since your avatar shows a vehicle on an incline....
If possible park the truck as such with the surge tank the highest point in the system. Fill, let it warm up to the point that the thermostat opens, purge/squeeze the upper hose.
Don't leave the water in the system for too long. If you have stray electrical charges running through the cooling system the tap water conducts electricity and in a short time you'll be replacing your radiator - electrolysis. Always use distilled water when mixing the coolant.
Vigilante
Vigilante
San Francisco, CA
Well I'm just afraid to drive the vehicle far enough to get to an incline like that. Thats not exactly in the neighborhood, lol.
I can jack up the front end, thats about it. But I'm still not sure if the thermostat is opening. I am not getting any reading at all from it after 10-15 minutes of idle time.
Vigilante
Vigilante
San Francisco, CA
All fixed. Ended up being the sensor that reads the temp was no good. System successfully flushed and replaced with new fluid at 70/30 coolant to water with new performance thermostat, gasket, and sensor.
Thanks for all your help guys.
