Thinking about a 2012 limited (not EL)
RI-Matt
Rhode Island
Hmmm... Seem to have lost all my friends with that one ;)
Still on the fence, looking at the regular length expy limited's now too. That said, I thought they all (Limited's) had max towing capacity although it seems some have the 3.23 or 3.43 vs. the 3.73?
This is getting exhausting.
According to Ford, the axle ratio makes no difference in the max towing capacity.
So a regular length Expy with 3:31's will tow the same as one with 3:73's.
Also, the "max" tow capacity is slightly higher with a regular versus an EL. ( 9200 to 8900 ) due to the additional weight of the EL.
Matt
G
gigantapithic
Calgary
Matt
Really? Is that on the 3rd Gens? When shopping for the last one (05 EB) it seemed that was one of my fails (of many), the 3.31 vs. 3.73. Has something changed between Gen 1 and Gen 2?
Actually finding that with the Chv/GM itineration's too. The 6 speed automatic seems to lesson the need for the lower gear ratio.
G
gigantapithic
Calgary
Matt
Can someone confirm the above two quotes please. I'm looking to buy this one (below, it's a 2011) and need to be sure it'll tow up to the max 9,200. I'm not going that high, but like the cushion.
Anything it's missing that I should care about? Going to test drive today. Here's a link to it:
http://www.kijiji.ca/v-view-image.html?adId=568600657&image=0&enableSearchNavigationFlag=true
Medium Light Stone Interior
Beck (D)
With Fr.Sus/Trans/Fuel Skidplates
With Manual Liftgate
With Under Floor Stowage
119"/3023MM Wheelbase
XLT
(-) Version Packages
Less Special Purpose Vehicle
Kentucky Truck Plant Build
Less Convenience Group
Less Special Value Packages
Less Memory Package
Feature Content Group 2
With Roll Stability Control
English/French NAS Language Label
English NAS Owner Handbook
With Electric Rear Quarter Window
With Privacy Glass
Standard Ovrhed Console & With Rail
With Full Floor Console
Adjustable Accl/Brake Foot Pedals
With Carpet Floor Covering Level 1
Front Carpet/Rubber Floor Mats
Rear Carpet/Rubber Floor Mats
S/V-DU Drivers Illum/Garage Dr Open
Less Stowage Bins
Less Cargo Stowage Rack/Rail
With Running Boards
Chrome-Plated
With Integrated Roof Rack
With Colour Keyed Wheel Lip M'lding
Lower Painted Cladding
Electrochromic Mirror With Mic
With Driver Electric/Heated Mirror
With Pass Convex Elec/Heated Mirror
With Black Exterior Mirror
Less Signal Mirror System
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less Rear Heated Seat
With Cloth 2nd Row Seat Material
Second Row 40-20-40 Seats
With 3rd Row Bench Seat
With Driver 6 Way Pwr.Seat Adjuster
Less Adjustable Passenger Seat
Less Programmable Driver Seat
With 3rd Row Cloth Seat Material
With Heavy Duty Trailer Towing
With Front Towing Hook
With Trailer Sway Control (TSC)
With Chrome Exterior Door Handle
Speed Sensitive Windscreen Wipers
Less Sun Roof
Front Bumper Painted In Bodycolour
Rear Bumper Body Coloured Painted
Less Front License Plate Bracket
Belt/Dr & Pa Fr/1,2&3 Row Restraint
With E-Coated Steel Spare Wheel
With 4 Wheel Tyre Pressure Sensors
17 X 8" Alum Painted Wheel-Exp Lugs
P265/70R 17 A/T OWL
With Super Engine Cooling System
Immersion Heater Engine
With 49 State/Non Green State Req
With Standard Suspension
3.31
Less Rear Axle Limited Slip Diff
With Chrome Exhaust Pipe Extension
With 4 Wheel Disc-Brake
Normal Fuel Fill
Less Fuel Kit - FIA
Less DVD Pack - FIA
With Remote Starter - FIA
Heavy Duty Aux Trans Oil Cooler
4X4 2 Speed Transfer Case With Tod
FFV-(Ethanol) Fuel
With Man Rake/Floor Shift Strg Col
Steering Wheel-Leather Wrapped + CK
Redundant Controls - Steering Wheel
With KMH/MPH Speedometer
With Message Centre
With Reverse Proximity Sensor
Standard Duty Battery
Less Power Convertor
AM/FM CD Changer/Clock
With Satellite Radio Reception
With NAAO Radio Frequency
Less Headphones/Sockets - Rear
With Premium Sound System
Less Television Package
With Media Gateway Module
With Universal Garage Door Opener
Less Camera
Less Driver Technology Pack
With Complx Refect Headlamp Design
With Daytime Running Lamps
Oxford White
Generic Country Group 2
(+)"CDN"
(-) GVMT Service Administration
(-)"USA"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"IS"
(-)"ATG"
(-)"PH"
(-)"AW"
TPO/Order Code 230A
Fleet
mtondreo
Florida
if you post the VIN up, one of us can check. My 2011 is 2wd, reg, 3.31 gears and has the heavy duty tow. There is supposedly a place on the hitch where you can look also, but the door sticker gives no indication (I just checked mine) and then re-ran the VIN to make sure.
Because your list has the Heavy duty trans cooler, it should have heavy tow (9200lbs). But I can verify with the VIN. You used to be abkle to just check and see if it has the round trailer connector (cant remember the name right now) and that meant it had heavy tow. Not sure if that is still the case.
Or you can just put the VIN in here Untitled Page and it will tell you.
G
gigantapithic
Calgary
if you post the vin up, one of us can check. My 2011 is 2wd, reg, 3.31 gears and has the heavy duty tow. There is supposedly a place on the hitch where you can look also, but the door sticker gives no indication (i just checked mine) and then re-ran the vin to make sure.
Because your list has the heavy duty trans cooler, it should have heavy tow (9200lbs). But i can verify with the vin. You used to be abkle to just check and see if it has the round trailer connector (cant remember the name right now) and that meant it had heavy tow. Not sure if that is still the case.
Or you can just put the vin in here untitled page and it will tell you.
1fmju1g56bef11214
Primary Features
Build Date: 18.10.2010
Vehicle Line: Expedition (2003-)
Body Style: 4 Door Wagon
Version: Ford Series
Engine: 5.4L 3V V8
Transmission: 6 Speed Automatic Trans (6R80)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.31
Emission: With 49 State/Non Green State Req
Air Conditioning: HD Manual Air Conditioning
Paint: Oxford White
Minor Features
Beck (D)
XLT
Less Memory Package
With Privacy Glass
Less Stowage Bins
With Running Boards
Chrome-Plated
Less Sun Roof
P265/70R 17 A/T OWL
3.31
Normal Fuel Fill
Less Fuel Kit - FIA
Less DVD Pack - FIA
FFV-(Ethanol) Fuel
With Message Centre
Less Camera
Oxford White
(+)"CDN"
(-)"USA"
(-)"GU"
(-)"BRN"
(-)"BZ"
(-)"IS"
(-)"ATG"
(-)"PH"
(-)"AW"
TPO/Order Code 230A
Fleet
G
gigantapithic
Calgary
no heavy tow on this one - looks like it is Canadian ( I may be reading it wrong, but you can check the link)
here is the link for the window sticker http://fordlabels.webview.biz/webviewhybrid/windowsticker.aspx?vin=1fmju1g56bef11214
sorry for the delay - it did not email me there was an update on this thread. I will check my settings.
Don't be sorry - it was pretty quick.
If I run the vin through this:
FordEtis home page
It shows these options (as I posted above)
3.31
What else would I need?
ezeq
canada
camper/trailer is what you need for the summer time. good day
G
gigantapithic
Calgary
Wow - did a complete about face and bought an F150 FX4, 2009 with 40,000 miles.
Primary Features
Build Date: 09.06.2009
Vehicle Line: F150
Body Style: Double Cab (3/4 Door)
Version: 150
Engine: 5.4L 3V V8
Axle Ratio: 3.73
Air Conditioning: High Capacity Air Conditioner
Paint: Ebony (Solid C/C)
• Charcoal Black Interior
• Apache Weave (A-L)
• Front Door Scuff Plates
• Stone Cuffs-Front MIC Black
• With Rear Mic Black Stone Cuffs
• Less Load Bars
• Less Bed Divider
• Less Front Load Bar
• Decal - FX4
• With Conventional Tailgate
• With 5.5' Styleside Box
• With Pick-Up Tie Hook - Inner
• Less Pickup Box Extender
• With Base Payload Package
• 145"/3675MM Wheelbase
• FX 4/Image And Power Off Road
• FX4 Plus Package
• Dearborn Plant Build
• Less Special Equipment Package
• FX4 Sales Badge
• With Power Equipment Group
• With Memory Package III
• Feature Content Group 2
• With On-Board Diagnostic System
• "US" Tailgate Badge
• English/French NAS Language Label
• English NAS Owner Handbook
• Less Fuel Label
• With Power Front Windows
• With Electric Rear Quarter Window
• With Privacy Glass
• With Power Sliding Rear Window
• Less Heated Rear Window
• Mini Overhead Console W/Stor
• Flow Through Console With Armrest
• Less Floor Mat Kit
• Adjustable Accl/Brake Foot Pedals
• Front Floor Rubber Mats
• Rear Floor Rubber Mat
• With Carpet Floor Covering
• With Illuminated Sunvisor - Drivers
• With Illuminated Sunvisor-Passenger
• Less Load Area Cover
• Running Board - Eliptical Chrome
• With Body Coloured Front Grille
• With Grey Wheel Lip Moulding
• Less Side Auxiliary Step
• Electrochromic Mirror - Video Cap
• With Driver Electric/Heated Mirror
• With Pass Convex Elec/Heated Mirror
• Ext Mirror Finish - Gloss
• With Signal Mirror System
• Less Adhesive Mirror Backing
• With Side Curtain Airbag
• With Drivers Heated Seat
• With Heated Passenger Seat
• 2 Row-H/Ser Flip Up W/Elon Cushion
• Less 2nd Row Folding Armrests
• With Driver 10 Way Pwr Seat Adjust
• With Pass 10 Way Power Seat Adjust
• With Load Leveling Trailer Towing
• With Front Towing Hook
• Less Fuel Economy Pack
• Exterior Door Handle - A - Gloss
• With Central Locking System
• With Door Entry Remote Control Unit
• With Keyless Entry System
• With Variable Intermittent Windscreen Wiper
• Power Tilt/Slide Sun Roof
• Moonroof Sw Open/Close One Touch
• Less Tu-Tone Accent Colour
• Less Body Tu-Tone Paint
• Front Bumper Painted Accent Colour
• Rear Bumper - Step Body Colour
• With Front Licence Plate Bracket
• With Driver Air Bag
• With Passenger Air Bag
• With 18" Steel Spare Wheel
• Tyre Pressure Sensors - 315 MHZ
• Premium Off Road Frt Shock Absrbers
• Premium Off Road Rr Shock Absorbers
• With 20" X 8.5 Aluminium Wheel
• P275/55R20 A/T OWL Tyre
• Spare Tyre - LT275/65R18 A/T OWL
• Market Road Condition - General
• With Super Engine Cooling System
• Immersion Heater Engine
• With 49 State/Non Green State Req
• 3.73
• Less Elect Locking Differential
• With 9.75" Axle
• Single Exhaust
• Less Exhaust Pipe Extension
• With 4 Wheel Disc-Brake
• Integrated Brake Control
• 4 Wheel Anti-Lock Braking System
• Roll Stability Control (RSC) Brakes
• Normal Fuel Fill
• Less Fuel Kit - FIA
• Less In-Dash Internet Device-FIA
• Less Tracking System - FIA
• Less Remote Starter - FIA
• Heavy Duty Aux Trans Oil Cooler
• Electric Trans Case With IWE'S
• With Skid Plates
• Extended Range Single Fuel Tank
• Non Locking Capless Fuel Fill
• FFV-(Ethanol) Fuel
• With Tilt Steering Wheel
• Leather Steering Wheel
• With Speed Control
• Redundant Controls - Steering Wheel
• With KMH/MPH Speedometer
• With Tachometer
• Display - Compass/Thermometer
• Less Message Centre
• Customer Info Display - Package 1
• With Reverse Proximity Sensor
• Heavy Duty Battery
• Branded AM/FM/MP3/6 CD In Dash
• With Satellite Radio Reception
• With NAAO Radio Frequency
• With Radio Subwoofer
• With Media Gateway Module
• Rear View Camera-Fixed
• With Daytime Running Lamps
• With Bright Headlamps
• With Front Fog Lamps
• With Illuminated Entry
• Tail lamps - Level 1
• With Automatic Headlamp On/Off
• Ebony (Solid C/C)
• Generic Country Group 2
• 4L34 5310 UA Left Front Coil
• 4L34 5310 UA Right Front Coil
• 9L34-5560-GA Left Rear Leaf
• 9L34-5560-GA Right Rr Leaf Springs
• (+)"CDN"
• (-)"N"
• (-) GVMT Service Administration
• (-)"USA"
• (-)"GU"
• (-)"BRN"
• (-)"BZ"
• (-)"IS"
• (-)"ATG"
• (-)"NCL"
• (-)"AW"
• Less Fleet
G
gigantapithic
Calgary
That's a much better package than you were looking at in the Expy. Enjoy!
Thanks - weird the build sheet didn't show it, but the sticker does. Also came with the HD tow package and it sounds like about 11,200 tow capacity. I'm lacking some room, but with only one kid and one dog the supercrew should do for the next few years and the towing issue won't be a concern.
Maybe in a few years I'll just buy a new expy.
No members online now.
Landsbutter
