Replaced my right cylinder head on 99 expy 5.4 triton. I only took off the passenger timing chain. When reinstalling the chain, the timing jumped. So, I remonved everything again and lined the timing chain mark up with the crank sprocket mark (single mark on timing chain) and the centered the cam sprocket timing mark up inbetween the double links that are black on the timing chain. Turned the moter over and sounded really rough. Could the driver side chain jump even though i never touched it?? Have taken this motor apart three times for this issue. Have had two different "mechanics" help and haven't gotten anywhere....any suggestions or pictures to help with this process....should I start over again and redo the timing to make sure it is correct? on some of the information that I have obtained, it says to remove the covers and then turn the crank key at twelve oclock. then use a a crank holding tool and turn the crank back. why is this? is that tool critical...
