To service transmission or not??
Darnold2001
Tennessee
I have a 2007 expedition 2wd. It has approximately 338,000 miles on it. As far as I know the transmission has never been serviced. It does have a 2-3 shift flare occasionally. Should I drop the pan an change fluid and filter or just drive it till it dies??
Yupster Dog
Moderator
What does the fluid look like?
Pink?
Brown?
Black?
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Does a 2007 even have a dipstick???
Isn't that they year that came with a pair of X-ray goggles, hence no dipstick needed, hahahaha.....
j/k :D
I don't know for sure about the older Fords/Expy's (both my '011 EL & my son's '09 Impala has one), but I know some more recent model year vehicles came without dipsticks, like my wife's '17 Acadia, which clearly states in the owners manual "this vehicle is equipped with a permanently lubed & sealed transmission"
Logan97
AZ
The 07 has that yellow handled short dipstick that sits on the passenger side of the trans. Have had to pull that out many times when I had my 07.
Logan97
AZ
When my 07 started having shifting issues I was at 233,000 miles. Changed the fluid and filter with motorcraft, issue stopped for about a month and came back. I say drive it until it dies.
KOTU
Los Angeles, CA
My '07 Lincoln Navigator L doesn't have a dipstick. When I did the timing work two years ago, I removed the front end, i.e. bumper, grill, condenser, coolant radiator, transmission fluid cooler, etc. to do the work on the engine. The transmission fluid was deep brown towards black. I lost a lot of fluid as it dripped from the open circulation lines that go from transmission to the fluid cooler and the fluid cooler itself. ... Damn, what a time not to have a dipstick. When I put it all back together, I refilled the transmission with three quarts of Motorcraft / Mercon SP through the top inlet of the fluid cooler. Whether I refilled the transmission system with the right amount or not, I'm unsure. I understand the 6-speed 6HP26 transmission requires 11.1 quarts of fluid. During the past two years, I have had no issues with the transmission. However, when I go down my long steep driveway and then down the steep street, the transmission seems to stay in low gear longer than I think it should. I don't know if the gear hesitation is caused by low or high fluid levels and/or cooler temperatures.
