I have an 03 5.4 4x4 that used to wander the road bad, spent a decent amount of $ and time making it drive better and its way better, replaced the front upper control arms, all new struts, belltech beefy rear swaybar, and planning to do front links soon. I got the wander down x10 but its still wandering the road, only recently did I notice its only when I have my foot on the gas cruising or w/e. Touch the gas itll have a slight pull to the left that you must counter steer to about the 1-2 o' clock position. Let off the gas and it'll rebound right. Coasting or in Neutral the truck drives perfectly straight-even with hands off the wheel it stays in lane.
Is torque steer even possible on a RWD? I crawled underneath and all the bushings from the diff to mounts look solid, no clunking either. Alignment is perfect, suspension solid as well, tire pressure good, tire tread good. Could weak belts in a tire(s) cause this? They are cheap tires (Kelly) that came with it but had low miles so I kept them on.
Thanks
Thanks
