Touch up Painting Plastic Dash Part
marlinpruett
marlinpruett
South Carolina
Well the sprayer clogged up on the first squirt!
As a temp fix I painted the dash part with a sponge brush and then sanded with 3000 grit but not happy with it. Will look for an alternate sprayer and redo the job.
I added a Iphone holder in place of the coin holder and that turned out good.
Paint was also slightly darker than original but hard to see difference.
Eagle 71
Nebraska
Marlin, you did a great job with the resto.
I’ve used the exact same sprayer that you used, and had the best results when the temp outside was a Goldilocks “just right” (not too hot/humid, not too cold). Don’t know the exact date you sprayed, but maybe the sprayer was used when the outside temp was a bit on the cold side (based on the sprayer clog you mentioned). Bottom line though, the results look great!
Adieu
SoCal
Any paint match recommendations for this case of nasty?
Adieu
SoCal
I took mine to an auto paint specialist and they had a special camera that matched paint.
You might try to find one in your area
For money as part of a painting job, or as part of the process of selling you a custom rattle can?
Whatever schemes they use in the XLT seem to hold up good. Mine hasn’t had faded at all. What is the Ford term for the XLT silver?
Kevin08
Illinois
I know this thread is older but thought I’d ad some info. I used Duplicolor vinyl & fabric spray, Silver. It matched my original 2008 Expedition King Ranch trims perfect. I had some difficulty with prep due to previous owner being a heavy smoker. Also may have been a bad first can I bought. After sanding most of the original silver off, waiting for warmer temps, and buying another spray can, it coated perfect and I’m very happy with it.
wiscoford
