rollinstone
2014 Expy Limited with HD Tow Package, including integrated factory brake controller. Does this package include the Trailer Stability Control? How can I verify if it does or doesn't? No help thru SEARCH.
Thanks, Monte...I have a disable button on the dash to disengage the Traction Control System (TCS), but there's nothing for the TSC...so I guess it remains engaged full time when towing.
Are you asking so you can disable it? If so,![]()
If it's anything like the trailer sway control in my wife's Explorer, I wouldn't put too much stock in it. For all it's sophisticated language that Ford uses to describe the feature, all it basically does in response to sway is apply the brakes causing compression on the hitch, which, except in hard turns or on slick roads, is the exact opposite of what you need. In fact, electronic stability control even cuts power to the engine, which actively prevents the very action (acceleration) that is required in most cases to add tension to the hitch to help mitigate sway. Now if the trailer sway control would apply the trailer brakes, instead of the tow vehicle brakes, that would be nifty but I have yet to see a car manufacturer develop that type of onboard tech.
I started disabling sway control on my wife's Explorer the first time a trucker passed me and my utility trailer began snaking. To it's credit, the feature on the Explorer did what it was supposed to and applied the brakes and cut engine power, but not before the swaying got worse and only got better when the vehicle slowed itself down to a manageable speed where I was no longer oversteering to correct the sway. Had the engine power not been cut, I would have been able to accelerate out of it or if my trailer had electronic brakes, I would have applied those manually from my controller.
Wow....I don't even know where to start with this post, maybe physics? PLEASE read up on how trailer swap control actually works before posting incorrect and nonfactual information. Trailer sway control has zero interest in adding or reducing pressure on the "hitch" whatever that means. It uses several sensors to decide if sway has occurs and then uses various methods to mitigate the sway. Apparently from the post above it saved your ass and you are still saying it's a bad thing.
