johnboneske
I got my Torque Pro and dongle installed in my Expedition. Temp outside was about 84 degrees, I was towing it today, for about 25 miles. The hottest I saw was 183.4 degrees, and that was going up a hill and under acceleration. Most of the time it was around 170. Solo I get about 160. I installed the two sensor PID's that seem to work, from the Ford downloads. The sensor 1 and sensor 3, sensor 2 does nothing for me... One is lower by about 4 to 5 degrees constantly. I will "assume" the lower one is the fluid going into the Trans, and the higher is the fluid coming out of it? The temps I said here are the higher ones.
How hot is to hot? Should I install another trans cooler? I have the factory larger one, not the tiny one. But, the external cooler is run in series with the other cooler that is built into the radiator. Should I bypass the one going into the radiator? Any help would be appreciated!
