Transmission cooling-can it be improved?
Mr Big
Tampa Bay, Florida USA
Struggling to make sense of that, not sure what reprogramming would do to change that? I do have a recall that needs to be done so maybe I will talk to them when I take it in and see if there are any updates that need to be done. What was the reason you have the pcm/tcm updated?
Recall and Technical Service Bulletin. I was not expecting anything to change except the false Catalytic Converter error codes. So, I assumed that maybe the PCM software update changed something to do with temps. I really don't know, but it was a nice surprise.
Bmac1955
Southern Cali
Read any info on the 10r80. I read that heat is the downfall along with CDF drum for these Trans. It is no wonder Ford redesigned the Stat. My guess. My 2019 is in dealership with 46k. Want them to replace the stat do to seeing high temps of 218 to 224. Highway driving doing 65 with outside temps of 70. Doesn't seem right to me. Will see. I do have Ford Protect warranty.
Calidad
California
My 2019 around 65,000 showed early signs of the Tstat issue but at that time I didn’t know about it. 820 miles over three passes in July heat pulling a permitted over sized boat thats around 8700lbs all up.
The early signs of the Tstat was slow to cool and not cooling off lower than 210 on the transmission. The engine temp doesn’t display till 228.
The transmission fan kicks on at 212 and is also on when AC runs. During that trip we ran front and back heaters full blast during climbs over the passes one was in 100 degree weather. RPM in the 2000-2300 range definitely kept heat down vs 2500+rpm. 230 is getting hot. 240 is hot and time to pull off or be heading down hill. I did pull off on our longest climb 2nd morning cooler outside temps and thats when I noticed we couldn’t get it to cool past 210 (note later after the Tstat replacement it cools down fast and lower than 210!)
Flat towing at 55-60 pre tstat replacement early on in the failure… Flat 90+ temps 212-225 with AC on was the range. Near the end of the 820 mile haul the Tstat issue was getting worse (again I didn’t know but could see the worse cooling issues developing)
Last 19 miles of that trip was over a 7400ft pass. At 5800 ft the cooling even after pulling off for 30 minutes was not dropping like it should and the heat spike was happening quicker I was pulling off at 230 because we had a long climb still. Called a tow guy to drag the boat the last 19 miles over the pass. That was July 1 2024. No more towing till October and that was from 6000 up to 7400 then down to sea level cooler temps fresh synthetic Penzoil Temps were cool ish 200-220 for 180 miles same boat. Then in December I was solo heading to the cabin at 70mph and got a engine temp spike and transmission 234 temp spike!! Bingo!!! I knew it was the Tstat!!!! Around town transmission was running 212-215 at that point. Updated the Tstat immediately 180-190 around town. Solo to the cabin 180-190.
Pulling the boat 25 miles mid day through stop and go traffic hell 215 then climbing up a decent grade finally out of traffic it cooled down!!! On the climb to 201!! At that point I knew that stupid Tstat issue was definitely my problem.. This years haul over the 7400ft pass I got to use a buddy’s 2024 F250 6.8L gasser 6spd AT. I watched the trans temps and it has a factory air to trans fluid cooler you can hear that fan kick on btw. 55 mph it ran at 190-200. Heavy climbs it actually cooled down because the fan kicked on 210 after traffic stop up a steep grind at 40mph and 3700rpm (different power band than the 3.5) it immediately cooled to 200 in about 4 minutes! The 6.8 doesn’t match the 3.5 pulling power till your in the 3500-4000rpm range!! Under 3500rpm you will not achieve highway speeds if 50-55mph. Vs the 3.5 at 2500-3000rpm the Expedition easily hauls my boat to speed getting on the highway hill or no hill. Very different experience regarding power between those two engines.
I do think an air to transmission cooler would be a huge deal for those of us dragging 7000+ lbs especially draggy trailers like boxy RVs and big draggy boats. Its definitely in my list of curiosity for possible modifications.
I want to eye ball my buddies F250 closer to see how Ford rigged the air to transmission cooler. I don’t think the F150 is setup that way (maybe the heavy payload F150 package? But those are pretty rare)
As for towing? This setup tows really nice with empty fuel tanks. Trailer is electric hydraulic 4 disc brakes huge discs! It stops well but not quickly. The F250 by the way didn’t stop it any quicker! The brake gain is different between the Ex and 250! The Ex I ran brake gain at the highest level. The F250 I ran it at 8. They were comparable in stopping between the two.
The Expedition engine braking was definitely effective and very important crossing three serious mountain passes over 5000ft. I even followed a semi down one of the more challenging passes that didn’t have any tail lights and seemed to be very conservative on engine breaking happy to just follow him I rarely used any brakes and when I did it was just to shed 5-10 mph with a short hard brake application then off to let brakes stay cool. When we hit the bottom the semi pulled off- I’m convinced he had zero trailer brakes and nursed that thing down the mountain all gearing given we got passed by semi’s absolutely hauling ass!!! Definitely not my thing!! 40-45mph on the long down hill steeps was perfectly comfortable for me!!!
D
duneslider
Utah
I have been watching closer and last night we did some mountain biking and did a little shuttling. With the bike rack and 7 bikes and 8 adults in the Exp and climbing the canyon I saw transmission temps of 219. Air was cool (65 degrees) but it was steep and elevation at the top was close to 9000'.
Just a note, this is with the updated thermostat that I just installed a couple weeks ago which in my opinion didn't seem to make any difference in the temps.
I have a long drive this week. 600 miles each way, no trailer, but 4 adults and bike rack with 4 bikes. Salt Lake to Sunrise AZ. I will keep an eye on temps as we cruise through the desert. I am suspecting transmission temp will hover around 214. Basically, what I am coming to fully believe is that the method ford is using to "cool" the transmission is not adequate and adding an air to oil cooler will drastically improve things.
I did find a high flow thermostate controlled transmission cooler valve that is set at 185. So, that could be an option to swap to the air to oil cooler but still allow for the oil to maintain a temp of 185deg...
Calidad
California
No trailer loaded pretty heavy with 4 bikes on vert rack pushing hard up the sierras 209 is the highest I see with the new thermostat
Mr Big
Have you gone in for the update that helps with the transmission temperature? After my 2019 was updated, my transmission temperature drastically dropped.
Calidad
California
Update like software? Or updated thermostat?
Grrumpy
Navy Law Enforcement
For info, the normal operating temp for the 10R80 is right at 215 degrees. This is the temp that the Ford tech's try approach to get a good trans fluid level.
It is not uncommon for the temp to hit 230-240 when under load/towing, and the fully synthetic ULV is good to upwards of 270.
Not saying it's good to run hot for long periods, but 220-230 is not something I worry about. Previous 2021 Ranger easily got to those temps when towing our travel trailer and never had any problems in 24,000 miles of towing.
Calidad
California
Fan on the Ex and the 24 6.8 F250 kicks on at 212. 215 is in normal range. 230 is warm-240+ is hot. 190-230 is within acceptable temps obviously based on conditions. 212+ in cool temperatures with zero towing you need to keep an eye out for issues given that shouldn’t be happening. 230 you want to be paying attention and slowing down if your towing at high speeds etc.
BMW2FORD
CT
All the GM vehicles I’ve driven with the same 10r80 and fluid run at 140 degrees trans temp all day long. I’ve seen maybe 155 heavy towing with friends trucks. They’re using an air to fluid cooler in front of the vehicle. Makes me wonder what GM was seeing and why they went that route.
pnwjetsled
sw wa
We had a 21’ Yukon XL and it never ran over 150* trans temp. Our expedition would run 215-220 empty. I did fords 180* thermostat and now the hottest I have seen is 216* trans temp towing out 7500lb TT.
F250Pilot
GA
I have a 24 Expedition Max, and I made this easy modification after experimenting with my 24 F250 equipped with the 7.3 Godzilla. Both have a transmission heat exchanger that uses engine coolant to first heat up the transmission fluid faster and then cool it off after it gets hot. There is a transmission coolant valve that the PCM controls, and it's right in front of the motor with two coolant hoses attached to it. Once the transmission temp is hot, this coolant flow is then regulated to the heat exchanger.
So I bought a 3/4" straight 2 barbed adapter and bypassed the coolant control valve so that the heat exchanger is getting constant coolant flow. I leave the PCM-controlled valve connected so the PCM thinks it's controlling the flow, hence no codes are thrown. My temps were 215-220, and now they are 195-200. A 6.00 fix to knock 20 degrees out of the transmission temp. I used 2 pliers that are made to pinch a rubber hose to prevent coolant loss while installing the 3/4" adapter.
I also installed PPE pans on both, along with Sonnax solenoid retainer clips, since they are easily swapped out during a pan swap. There are 6 solenoids on the 10R80, and the small oem clips get weak and allow the shift solenoids to wobble or cant and the end result is the movement of the valve that the solenoid is trying to move is reduced. Clutches get reduced pressure. The clips are cheap, and they have a rolled edge on top, so the other side of the clip doesn't collapse like the OEM clips do. Another 6.00 cheap mod, and you don't have to remove the VB to change them out..
D
duneslider
Utah
I haven't followed the lines on the expedition, where about are you doing this bypass? Any pictures?
With those clips you mention, what symptoms are seen when the oem clips have collapsed and the solenoids aren't working right?
F250Pilot
GA
Here is what Sonnax says what happens to the oem clips.
Here are a few pictures. I put red caps over the oem flow control valve to keep dirt out. The picture with the two hose clamps is where the 3/4" straight fitting is. These pictures are taken from under the front of the truck.
Member Recommended
xojgiiox
