Franklin Jones
G’morning! One of the pieces of maintenance I need to do before spring (and camper towing) is transmission fluid service. I have two questions for you:
1. Anyone pump fluid out by disconnecting a cooler line and doing a diy at home “flush”? Or is a simple pan drop the preferred method around here?
2. Anyone have experience with Valvoline ATF maxlife? It says it’s spec’d for Merton LV as required for my transmission, but I’ve always been leery of third party fluid in the trans. Anyone use it with success? (The folks over at BobIsTheOilGuy dot com give it glowing reviews)
TIA
TIA
