Hi all, I think I finally fixed my leaking transmission problem. I have a new problem, my truck seems to shift from first to overdrive, then shudders while trying to match engine RPM to overdrive. It sort of feels like a miss but a shudder/stumble is more accurate. I checked for vaccum leaks, cleaned MAF, spray cleaned throttle body, changed coils and plugs, installed new air filter, added fuel system cleaner and it still shudders/stumbles. I scaned for codes, no codes using my scanner, I had Oreilly auto parts scan for codes, no codes. The idle is smooth until you put in drive, it might shudder/stumble sometimes, once under way if shifts right to OD, I think. I changed the trans filter and fluid, nothing has helped thus far. Any ideas are appreciated, thanks.
