Truck wouldn't start. Second time.
NC-Expy
Apex, NC
So last week right after I got gas at the gas station I tried to start my truck and she just wouldn't start. I kept trying and trying, still not luck.
Finally, I put it in Accessory and threw it in drive and then put it back in park and it started.
Today the same thing happened in the Best Buy parking lot, I threw it in drive and then park again and then it started.
What could it be? Alternator?
toms89
technical advisor
MD
Sounds like it possibly could be the park/ neutral safety switch.
SOLISIMO
Ft. Lauderdale
I know autozone you can take your alt. to have it tested. When you start your truck do the lights dim?
toms89
technical advisor
MD
Does it crank at all and does not start or no crank??
NC-Expy
NC-Expy
Apex, NC
What lights? I mean everything works fine. It's just these two instances where something has gone wrong. Never happened before in its life.
toms89
technical advisor
MD
Safety switch!! Will not let it start unless it is in park. By changing the gear shift you altered the contact.
NC-Expy
NC-Expy
Apex, NC
Safety switch!! Will not let it start unless it is in park. By changing the gear shift you changed it.
So how do I go about fixing it?
Is it bad that I started it this way? Otherwise I don't think it would have started.
Should I get it fixed fast or can it wait?
ExpyPlowGuy
I concur +1. It's not bad for your car starting that way. It's just a safety feature that if the car is not in Park or Neutral it will not start.
toms89
technical advisor
MD
No not bad starting it that way.... not sure where its located in the expy. Tranny or the shifter?? Have to do search..
JUST4FUN
Admin
Moderator Administrator
Il
hey next time put it in newtral see if it starts
toms89
technical advisor
MD
If you just had it replaced and it is close I would take it to the tranny place. They should know what to do and should be quick fix.
