truxxx vs. daystars
tallsville
LA
i've been looking into lifting/leveling my 03 4x4. i've been looking at both daystars and truxxx. the both seem to be good. daystars say they don't transmitt vibration/noise into cab. the truxxx say i can fit 35's with no rubbing and daystars say 32's. any feed back would be helpful.
Lane24
technical advisor
Alberta , Canada
Rptr00 has the Truxx lift on his 04. You can check his thread about two spaces below yours in the Suspension area. Looks great, I'm pretty sure he is happy with it from what he said in his thread. Ask him...
rptr00
Las Vegas
Well I havent noticed any vibration in the cab whatsoever. The ride is as smooth as before the install. IMO, the daystars look more difficult to install. I was running 32.99 tires w/o the lift, so adding 3 inches should clear 35's. The only issue will be the wheel you choose. Backspacing will be critical. I am running the OE Ford 20's on 275 60 20 and the front rubs the lower control arm at full lock. I may pick up some 1.5" billet spacers to fix the problem.
dgray69
upstate ny
im running daystars on mine got 32s on with room for 35s, mine wasnt to hard to do and cost less than 200$
