Yep, will be back there after May 12th. In the Chicago area right now on a long-term contract with Motorola.
The cam basically dictates the powerband RPM of the engine. More duration shifts the power upward. You could get away with a little more duration but it isn't really worth the cost. When you go with bigger heads and intake you velocity will suffer further hurting your off-idle torque. You can usually offset this with a higher stall converter. I assume you are thinking about upgrading to the PI heads and cams that came on the 2000 and up trucks. This would be okay I guess, but you will notice a little bit of torque reduction. It isn't worth going any bigger than the PI cams. You can only go up another 5 degrees or so. There are cheaper and easier ways to make the truck quicker, but if you are doing a complete rebuild, the 2000 and newer hardware is a good base to start with, but you will need a custom chip to move the transmission shift points upward and get a converter with a bit more stall. The newer 4.6 engines make more power up top with a bit less off idle. The newest 2 valved motors had a flap in the intake manifold controlled by the computer to help keep the velocity up for improved low end.
Just my 2 cents.
Matt
