Upcoming Trip Advice
Gmas15
Boston
Hello All,
So, I finally convinced my wife to let me tow the RV from MA to Orlando for a family trip - staying in Fort Wilderness campsites with kids and other family. I love the idea of a road trip and we’ll do a little sightseeing on the way. She’s not that keen on it, so just posting to get thoughts on any recommended service pre-trip? Hate for something to go wrong. :)
The background - our Expy is not new anymore - 2019 - with 84k miles. We tow the camper a few times year mostly in NE or NY. It’s about 5000lbs dry, probably closer to 6000lbs loaded up. We have the heavy-duty tow package. I’ve kept up with regular oil changes, of course, but the transmission seems to be clunking more lately. And when cold, I’ve noticed a stickiness to the gear changes until warmed up. The other problem is I think we have issues with the vacuum sealing on the front left hub. If i put it in 2H - definitely get this loud grinding/rattling sound. Doesn’t happen in 4A. Then the suspension is definitely getting softer. And the pads and rotors were replaced at around 55k.
I called the dealer to talk to a service “advisor”, who just said that the tune up and transmission fluid change recommendation is at 100k. Nothing new to do. I’m not really a serious car guy, so just looking for thoughts on any preventive maintenance, like asking what any of you would do, if anything, prepping for a trip like this?
Thanks!
George
99WhiteC5Coupe
Hello All,
The background - our Expy is not new anymore - has about 84k miles. We tow the camper a few times year mostly in NE or NY. It’s about 5000lbs dry, probably closer to 6000lbs loaded up. We have the heavy-duty tow package. I’ve kept up with regular oil changes, of course, but the transmission seems to be clunking more lately. And when cold, I’ve noticed a stickiness to the gear changes until warmed up. The other problem is I think we have issues with the vacuum sealing on the front left hub. If i put it in 2H - definitely get this loud grinding/rattling sound. Doesn’t happen in 4A. Then the suspension is definitely getting softer. And the pads and rotors were replaced at around 55k.
Thanks!
George
You did not mention the year of your vehicle.
If it were me - driving that distance pulling a trailer with my family, I would have the transmission fluid changed and the following.
Are the spark plugs original? If so, I would change them or have them changed. The Ecoboost engines are hard on spark plugs.
Check and replace the engine air filter if necessary. Check and replace the cabin air filter if necessary.
I would also have the vacuum issue with the 4WD evaluated and repaired. It is often as simple as a broken or leaking vacuum line or connector. While the system defaults to AWD if there is a serious leak, the vacuum leak could affect the engine operation.
Brakes - have the thickness of the brake pads checked and replaced if marginal. Use OEM pads.
Lower and inspect your spare tire. Ensure that it is inflated to the proper level or a few pounds higher. Ensure the jack and tools are present.
Check all the exterior lighting and replace any bulbs as necessary.
I would have your wife carry the second (or spare) fob for the vehicle. You don’t want to be stranded if you lose your fob.
Going_Going_Gone
Phoenix
Assuming by your sign up date that you likely have a '18 or '19 model. The thermostat in these has been updated and, depending on if you ever had your cooling system serviced, you might consider a new thermostat and system flush. There is also an improved iwe check valve which is a very inexpensive diy part that may cure your hub noises. Make sure you bring along a decent (bottle/floor) jack and maybe a battery operated impact gun.
slow3v
Thermostat + housing, coolant hoses for the heat, plugs and coil boots, differential fluids and transmission fluid, transfer case fluid.
Good places to start. CDF drum may be in your future but likely out of warranty it sounds like. Do the preventatives though and you'll have a good experience.
Left Coast Geek
Mid Left Coast
on my 9900 mile Mexican loop last year, at about 70000 miles a heater 'Y' hose near the engine split and started dribbling coolant. After dumping a few gallons of coolant ready-mix into the engine over a few weeks, I stopped at a Ford dealer in Guayamas, it would have taken a week to get the hose from Ford, so they bypassed the heater til we hit the states and I got it fixed in Phoenix (Sandersen Ford, freekin biggest dealer I've ever seen).
Fastcar
Army
FL
Do the shocks! Your towing and you don't want a quick lane change to up end you. Don't use I 95, I 81 is less stressful.
byathread
Pennsylvania
Great suggestions so far. If you don't have new tires on the Expedition, get them. Check dates on trailer tires and if older than 5 years, also replace. Spares good/spec'd w/air as well. Is your weight distribution hitch dialed in/as level as possible. IRS squats, regardless, but shouldn't be too bad with your tongue loads/a good WD hitch setup. Grease that too if it has fittings. Check receiver and hitch and all connections for rust or broken welds and check trailer brakes function with brake controller. TPMS for trailer tires? Grab 10 and 2 on the trailer tires and pull/push as hard as you can to check if any bearing play and get that addressed, too. Feel trailer tires and hubs just off highway. Dielectric grease trailer electric connections, especially if you are doing this trip on the pickled roads. A jump pack can be a life saver too.
byathread
Pennsylvania
Run in tow mode also, it shifts through every gear and stiffens the rear ccd shocks (@Deadman's sway bar suggestion is ideal for the ride)
