Update all versions of Ford Sync 3 to the latest Sync 3.4
Overtow
CLEVELAND
2. Waze via what? Applink? CarPlay? Android Auto? Aftermarket Wifi Adapter?
Waze via Android Auto. Its worked fine for me for years, but I just recently upgraded to a new Pixel 6a and I started having the problems shortly thereafter, maybe immediately on the switch. I was hoping that the 3.4.22110 upgrade would solve the issue but sadly that is not the case. This is likely a Google issue:
Jharpe
O’Fallon, MO
Has anyone had issues with the ambient lighting after updating? I just updated from 3.0.17276 to 3.4.22110 and now my ambient lights are not working. The function is still there in the menu. I did the master reset as suggested by Cyanlabs at the end of the update. I have an ‘18 max platinum.
LokiWolf
Moderator
Richmond VA
Master reset is hardly ever needed. Most of the time a simple reboot of Sync, using the method I described above.
For an 18, hold the Radio Power button and Next Track, until screen goes black. Do that 2 times in a row, then try the menu again.
Overtow
CLEVELAND
Ambient lighting works fine for me on 22110.
Jharpe
O’Fallon, MO
That reset worked. Thanks LokiWolf! Saved me from the doghouse with the Mrs!! Lol
MxRacer965
Hudsonville, MI
Anyone keeping eyes peeled for a Sync 4 update? I would imagine should this even be possible it would require some new hardware. I think infotainment.com has a F150 kit to go from Sync 3 to 4 but I haven’t reached out about Expy. I’d pony up for new version if I had to buy some new hardware. I plan to keep the Expy for 6-7 more years or so. It’d be worth it to me.
LokiWolf
Moderator
Richmond VA
Haven’t looked at the 150 kit, but would probably work. Yes, will need new hardware.
LokiWolf
Moderator
Richmond VA
What benefit is there in Sync4 other than the warm fuzzy feeling of having the latest firmware? :)
-- Chuck
Wireless CarPlay, and the ability to use Factory Nav with CarPlay active. The nav is "Connected" also. As in it has some internet based features. The interface is a little cleaner, and the new APIM is quicker with better hardware.
LokiWolf
Moderator
Richmond VA
Fill out this form!
https://forms.zohopublic.com/infota...a/m7R2exajUQkfs2WJO8mkDzUcYC2HIt5WrUWxFICnigs
I contacted their support and sent my VIN on my 2020. They said not yet, but more requests would help.
Rob6805
So something surprised happened tonight. All of a sudden the Sync update pop up appeaead letting me know that an update has been installed. 3.4.22200
MxRacer965
Hudsonville, MI
LokiWolf
Moderator
Richmond VA
Yeah, Ford's over the air system has seen some major improvements over the past few months. They had too! with so many vehicles on Sync 4 that is dependent on the Over the air system.
LokiWolf
Moderator
Richmond VA
I’ll do that first thing in the AM. Absolutely will buy a new APIM if I can get to Sync 4. My 2019 Ram 1500 with UConnect 4 and wife’s 21 Grand Cherokee L Summit with UConnect 5 both make Sync 3.4 look like a pile of garbage.
Yeah, UConnect 5 is still better that 4, but 4 is definitely an improvement over 3.4.
chuck s
Sync updated all by itself when the vehicle was shut down? How does this work? I have automatic updates set, my Wifi is recognized, and the signal is at least Fair.
3.4.22200 and 3.4.22251 show available with the CyanLabs software and this process works for me but resets everything including all my GPS saved data so I'm hesitant to "update" with our a very good reason.
-- Chuck
LokiWolf
Moderator
Richmond VA
-- Chuck
Chuck the 16-19, and early 2020's will most like not see any over the air updates. The APIM firmware does not officially support the current releases of Sync 3.4, or any 3.4 for that matter. So Cyanlabs is the only option.
Most 2020's and 2021's have the later firmware, and there for support 3.4 and any of the current available versions officially. They should see over the air updates as Ford gets its act together. Those will go away soon too, once Ford goes to Google based root OS and away from QNX.
