updates on my fiberglass box
03blkstanggt
maryland
just wanted to show the updates that ive been doing. almost done now i need to finish sanding and paint
viewgallery.php
[/url][/IMG]
Hampton, VA
looks good...how much space are you using...cubic ft per sub?
03blkstanggt
maryland
i cant remember off the top of my head. the box is fully open on the inside. i didnt close off space to each sub. i remember i went a little bigger than the manuals called for in the books, but i started this project about 2 months ago and cant remember exactly
Hampton, VA
are you making it to work with the 3rd row up or down?
03blkstanggt
maryland
it will work with the 3rd row up
its just a stock stang =)
its got a vortech charger running 10 psi 475rwhp 480rwtq <--numbers on a blown transmisson, no third gear
automatic with 3000 stall fully built chromoly suspension
all work done by me and i had it tuned by jpc racing
still stock heads cams and bottem end, but thats going to change very soon =)
riccoh
honolulu, hi
you might want to have separate chambers for each sub, also if you are going to use those kenwoods, remove the plastic cover fo rthe magnets, they will come off in the box and vibrate like crazy..
Hampton, VA
whats da advantage of seperate chambers compared to accumalitive area space?
riccoh
honolulu, hi
saund waves tend to cancel each other out in close proximity, so it wont hit as hard as it should, like when there are separate chambers, specially if you are running out of the mill subs, that are average at best. not to mention distorsion ar higher volume. just my 2ct,
FukNshT
