Used? Rebuild? Remanufactured? Rear Diff
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
9.75 ring gear 3.55 LSD needs repair. Truck has lots of new parts runs strong and I need to keep as tow rig. I will semi retire it after this repair.
Truck has 240,*** miles.
Recommendations?
lonestarjeff
The Colony, TX
I put a Detroit TrueTrac in my 2000 F150 at 240k miles. It has the 8.8 though. I can't even tell it's back there in the dry.
Machete
Machete
Illinois
We completely rebuilt the rear diff. I have the 9.75 LSD. Also did the axle bearings and seals while there.
I’m breaking it in slowly and gently. Just up to 200 miles on break in. After 500 I’ll switch to Amsoil fluid and put a new diff cover.
I burned up the diff w constant high speed driving for hours on a daily basis in 95 degree weather. The oil should have held up better it only had less than 70k miles since last change. I won’t use motorcraft oils anymore. They offer the minimum protection for factory specs. I’m sure it’s fine for the suburban soccer mom wagon use but for heavy duty both the motor oil and gear oil is subpar.
Machete
Machete
Illinois
Yes. Parts and labor. Parts including both pinion and ring gears which actually looked fine. It was a couple bearings.
Just about 500 miles on easy break in now so changing oil to Amsoil and putting a new diff cover. Original looks ratty.
