Used Tires and A4wd
Scottandtyson210
Puyallup, WA
Will tires that dont have the same tread wear all around mess up the truck?
I know tire shops wont sell you just 2 when you have A4wd.
panda24619
San Diego
shouldnt do bad. just keep keep the ones in the rear the same and the ones in the front the same. if they are just mm's off then it wont be a big deal.
walnuts4x4
Watertown, NY
depends on how "bad it is".... just try to keep the rear the same... I had one tire wear bad when I had to replace ball joints/wheel bearing... so when I rotated them I had a bad vibration for a week or so till the wear became less noticable
2000eb
pull your 4wd fuse. it will stop the truck from engaging into 4wd at all.
