Hi All,
I know there are different beliefs for this so I'm hoping to get some feedback for my specific scenario. I have a 2001 that I'm going to tow a 1970 Mercury Cougar Convertible with. I'm going roughly 175 miles (+/-5 miles) on what I would consider pretty flat land. Probably going to leave early in the morning when temps will get to maybe a high of 70 by the end of the drive.
I do not know if my expo has a tow package or any of the accessories that it came with. I'm using a u-haul trailer and connecting with a regular 4 pin connector. I'm driving in CA so the max speed I can go is 55MPH. I don't anticipate that the car will want to shift from O/D to 3rd frequently hunting for gears, if it did I will definitely turn off O/D, but am unsure if I should drive with O/D off anyway.
The arguments I have read are that leaving O/D engaged and allowing it to be used will cause more heat. The resulting higher heat will be more harmful and a higher likely to risk the transmission. The other side of people believe that provided the transmission is not hunting, allow the transmission to use O/D. This will allow the engine to work less and result in better mileage.
I checked the owners manual and it did not say in the towing section to disable O/D while towing unless you needed the engine braking or preparing to accelerate in hills basically. Although I always try to get the best mileage, I do not mind driving with O/D off if it in some way would be better for the overall health/longevity of the expo.
For anyone truly interested:
Driving between Chico CA and Oakland CA. I don't plan on speeding I will just get behind a semi and use cruise control at 55 probably. Thanks for your thoughts.
