Greetings,
I picked up a 99 XLT/5.4 last week knowing that it was running a little rough. I could not pass it up though as its previous owner literally has OCD and has taken meticulous care over its 200K life thus far – it is mint.
I was throwing 2 codes indicating it was running lean and misfiring on #3. First checked for any obvious vacuum leaks and ran some treatment through it as it had been sitting for a little while prior to my purchasing it. I replaced the coil and plug on 3 but the issue remained. Finally, I had a shop test compression and it appears that #3 is at about half compression. I am surprised considering that it has had all factory services for its entire life thus far. I am thinking/hoping that it is a valve issue and my mechanic concurs.
It has a brand new Trans and most everything else on this truck is close to new so I am not willing to give up on it by any means
Question(s):
1.Do you folks agree with the diagnosis or have any other thoughts on what it could be?
2.If it is in fact the valves, has anyone done a valve job on these? My mechanic said it was likely as simple as replacing a spring that has broken down over time
3.Should I just swap the motor? I can get a 5.4 crate for $2800 brand new and warranted (haven't shopped around much but think this is a decent price).
Any stickys or helpful links would be appreciated as I have been combing this forum for a while and not finding any detail outside of electrical component cleanings and various smaller fixes for this issue.
Thanks much!
Question(s):
Thanks much!
