Want to go lower...... Drop spindles or springs??
WHOISMOOTOO
Dallas, TX
LOOKING TO FINALLY GO LOWER... WHATS BETTER DROP SPRINGS OR SPINDLES AND OPINIONS ARE APPRECIATED!:shrug:
KWT2000
NINE MILE FALLS
im thinking drop spindles would be better for ride quality... but you have to do springs in the back rite???
thats what im thinking
walnuts4x4
Watertown, NY
that makes more sense... springs in the rear and spindles up front.... kinda like a suspension lift but opposite... damn tired right now... but that makes a lot of sense
jacks3am
michigan
park next to walnuts to make your car look like its laying frame?:joke:
Newport News, VA
i think i can only do spindles since i have air all around...let me know what spindles you get...should i drop it when i only have 3 in after the air goes down when parked?
EMendoza93
The only drop parts available for the 03+ is the springs. Everything else is custom. Just do the belltech springs with one turn cut, for 3.5 drop. But with anything more then 2" you'll run into camber issues. Also transmission crossmember will scrape so watch where you go.
Ross, you should just add a tank and compressor to make your oem bags adjustable.
WHOISMOOTOO
WHOISMOOTOO
Dallas, TX
And the lowering god chimes in! After a shit ton of research I'm going belltech springs since eibach is only 1.6 and 1.8 (barely unnoticeable for the money) and belltech will just flat out go lower. My question now is will the stock struts hold up pretty good or SHOULD I replace them? I'd like to keep pretty good ride quality if possible
SOLISIMO
Ft. Lauderdale
Please dont cut your springs as recommended by some. People seem to forget about spring rates when cutting them:Grenade:
Newport News, VA
i'll check around to see if that will work...
MOOTOO...replace the struts...its not advised to compress them for this application...if youre gonna do it...do it right...new struts
WHOISMOOTOO
WHOISMOOTOO
Dallas, TX
ross, thats kinda what i was looking into and the only one i seen like that is the ground force kit. which struts would be the best for this application? i cant see compressing the factory struts and them still operating normally without "dialing them in" or replacing them but then again im not a suspension expert ... rims/tires, mobile audio/video, electrical work, shooting people, blowing up buildings, jumping out of aircraft i can help you out all day!
