Washer fluid ?
aka rotten
Ga.
Yesterday washer fluid ran out on wife in 2000 Expy,.Says lil pic of window with wiper in it came on. She stopped at local place and had em refill, alls fine cept light still on. Never had that happen before in years we owned it, what do I need to do to get light off.Thanks
Bedrck47
Elizebethtown, PA
take and wiggle or turn the connector for the low washer sender just be careful that you don't break it
let me know if that solves the problem
A
aka rotten
Ga.
She,s out running in vechicle now,i will check bit later.I,m not a mechanic,am I right assuming connector your speaking of is under reservoir?Thanks
Bedrck47
Elizebethtown, PA
I believe it is on the side Friend had the same problem and that is what cured it hopefully it cures yours
A
aka rotten
Ga.
I hate that didn't seem to work but I jiggled it a bit and nothing happened as far as light goes, Washers work fine. Recon wouldn,t hurt to leave light on but just bugs us .So what would be next step?
Bedrck47
Elizebethtown, PA
The low washer fluid indicator does not operate correctly
Washer fluid level switch.
GEM.
Circuitry.
the switch is open when the level is full
as the level drops it will cause the switch to close and activate the low warning lamp
if you disconnect the connector and the light goes out then the switch is the problem
but if the light still remains on then it could be a problem in the GEM or the circuit
A
aka rotten
Ga.
GEM.
Circuitry.
Well someone else pm,d me and said to unhook battery for 5 min. Ifthat didn't work,replace sencer.Just gotta chane this morn to try that and dam light is out.So just wanted to let yall know,guess problem fixed itself.Still think yall right bout float being stuck.Thanks for suggestions ya,ll.
