Water leak maybe? A/C?
jdpate1018
Tampa, Florida
So the other day when I was cleaning the expedition out I noticed water under thre floor mat on the passenger side and thought it might have been from when my mom spilled water on the floor. But today my sister noticed water coming from where the carpet meets the plastic in the center console, and I noticed it on the drive side in the same spot. I looked at the windshield leak thread and this doesn't seem to be the same thing
stamp11127
Temple, Georgia
Has it been raining down there? If so check the fuse box under the dash and see if it is wet also. If it is then the windshield is leaking, if not it may be a clogged drain on the a/c.
BAD RONALD
Fairfield CT
Had a problem like yours with a '11 Edge. You could hear the trapped water slosh behind the dashboard when driving through turns. The car had a condensate drain blockage and water from the AC was failing to drain to the ground. I found the drain connection, separated it and cleared the clog with compressed air forced through the line.
I never had to look for AC drain routing on my Expedition, but the problem you are having sure sounds similar to the Edge.
