Water leaking into rear area behind 3rd row seats
rwr841
Anyone ever have water getting into the rear behind the 3rd row seats? This 2020 expedition only has 20500 miles an after sitting parked in a heavy rain water leaks on the carpet on drivers side behind 3rd row
JamaicaJoe
Oviedo FL
My Gen 1 Expy has a plastic vent that is concealed inside the upper door jam of the rear hatch. It is designed to equalize air in the vehicle. If it comes loose, water gets into the channels above the rear section, and in my case dripped down from the upper trim to the side panel rear drivers side.
fomoco1964
San Diego
Does it have a sun roof? It could be the drain has come disconnected. There are four of them, two at the front and two at the rear.
Retiredusps
N.J.
Wifes had same 2 dealers cleaned drains. Still leaked. trird dealer said sun roof glass was bad incorect cut. finally got it replaced NO MORE LEAKS. Seems it was a problem some glass was warped and would not seal.
fomoco1964
San Diego
Two days after I bought my truck we had a huge rain storm and my son found water in the cup holder in the third row and the headliner was soaked. Turns out when the truck was rolling down the assembly line the drivers rear drain hose got pinched under a roof support and disconnected from the sunroof. Dealer fixed it right up and no problems since.
