Wheel spacers
BIG GREEN FORD
loxahatchee Florida
I can check for you but I think it will need to be grinded. If you get any get the ones that I posted here they will not give you any vibrations. As long as you install it correctly
lve2wheel
lve2wheel
Whitmore Lake MI
I havent had any issue with mine. We ordered the same spacers to the best of my knowledge. I love them. No vibration other than the tires. I didnt loctite mine but its pretty much a toy. They need to be able to come off an back on regularly. I highly recommend them. If you have to cut the studs to fit the 1 1/2" spacers, i would recommend going to the 2". Cause if you ever want to take them off, you have to restud the whole truck. Which at times is more difficult than not especially on the back. Just my recommendation. Hope this helps.
98EXPnSRQ
Sarasota, FL
1.5" spacers will mount with the stock lugs. They measured under 1.5 on my 98. Also i can confirm that 15" wheels do not fit front or rear.
BIG GREEN FORD
loxahatchee Florida
Yea they hit the brake caliper, I didn't find 1 1/2 inch spacer hub-centric so I went with 2in hub-centric
98EXPnSRQ
Sarasota, FL
They barely hit in the front and you could grind a bit and they would fit. The rear caliper clears but the dust shield hits.
BIG GREEN FORD
loxahatchee Florida
rear installed
Love the way it throw's mud everywhere! PERFECT just what I wanted :)
