So I try the button on the end of the stalk and nothing happens. The wipers work otherwise on all the variable speeds. Just not the wash/wipe feature. Swapped the two relays and no change. So I took the reservoir off, took the offset two prong plug off the pump, took the hoses off the pump and took the other two prong connector off the reservoir. Cleaned all the contacts and lightly worked the corrosion off the sockets with a flat file. plug the pump into the connector for yuks and low and behold, the wipers work and the pump spins. Put it all back together and nothing. I'm open to any suggestions...
