Your Battery Keeps Going Dead... The Parasitic Draw Test
Newport News, VA
get ur alt tested to...if its going bad it will drain battery and you'll go through them
AVERY CONFER
Bay city michigan
I'll test it this weekend. I'll bust out the multimeter and run a drain test. It could be the alt not charging properly too. The battery usually lasts a couple days before I need to charge it and then I start the truck the volt indicator on the dash stays towards the low end, implying the alternator isnt charging the battery? Maybe? I guess I'll find out tomorrow. What's the best way to diagnose a bad alt?
Also keep in mind the battery is fine. Brand new Duracell not even a month old. Puts out the proper voltage when charged.
Charles Musick
Va Beach
Temple, Georgia
You can use either terminal. The only difference is the polarity connection between the meter and battery cable.
