Only One Front Speaker
fergie2012
Des Moines, IA
I picked up an '04 EB at our local dealer auction and am having a couple of issues I haven't run across before.
The instrument cluster has gone out a couple of times for approx. 10 minutes, and by searching other threads, am under the impression I need a new cluster. It happened to have been raining rather hard, so I was thinking that may have been the reason.
The big problem I have is now only one of my front speakers is working. The left driver door speaker is working. The one in the rear left door, and neither one's on the right side are working. I took the head unit out and have checked every connection I can find, but can't locate a problem (yes I have adjusted fade and balance).
Any suggestions would be appreciated.
Hampton, VA
check the wiring in the door jam and make sure they arent damaged...also...make sure the speakers are there/hooked up
jcason94
