Anyone use the Rancho Quicklift shocks with a 2.5 inch lift???
fat nick
Hampton, VA
118k and my stock Ford shocks are DONE! Already have a 2.5" Daystar lift on it with the spring bucket in rear and spacer on front. Since my shocks are toast I was looking at the Rancho Quicklift series. Part# RS999767 and RS999796 for my truck. Wondering if anyone has put these 2 together, and if so does it work? And looking at the site they say 275/60/20 can be run with just shocks. I'm currently running 315/70/17 on mine. Which is a 33 and I'm running a 34.3. So looks as though I could run bigger or have more room???
SkyJumper
SW Florida
I do not know what you mean by Quicklift, these shocks are nothing extreme except for the shaft diameter is a little larger than norm, they add no lift capability at all. I also run a 3/2 lift, and 305/70 tires. I purchased the 0-4" Rancho RS 5000 shocks for all 4 corners. They work great in my opinion, I have had them on there for little over a week now.
rear
http://www.summitracing.com/parts/RAN-RS5112/
front
http://www.summitracing.com/parts/RAN-RS5237/
ZombieSoldier
Ludowici, Georgia
Yes and no. The take the factory struts and just move the spring bucket higher... Not really a coil over per say but similar concept.
SOLISIMO
Ft. Lauderdale
I think his question is can he stack the spacer on top of the rancho quick lift.
sgtowing
Supporting Members
Valrico, Fl
I also think that is the question and I don't think anybody has done that. On Rancho's website it says it raises about an inch. I would imagine it could be done. If anything, it would probably just wear out ball joints and cv joints faster. How much faster, idk. With that much lift, you also might need to extend swaybar end links and brake lines.
Sent from my DROID BIONIC using Tapatalk
SOLISIMO
Ft. Lauderdale
Ive been dying to do it but Ive been told that I wouldn't be able to get the truck within alignment specs...
sgtowing
Supporting Members
Valrico, Fl
Ok, who's gonna be the guinea pig???
F
fat nick
Hampton, VA
Well I'm gonna do it. I'm service manager of a firestone so alignment and premature suspension components wearing out isn't really a big concern of mine with the discounts I get. Should have em on in a few weeks. Ill take some before and after measurements and pics.
edyk1986
