ac compressor removed and tightened the manifold bolt then replaced it on the motor. rented the vacuum pump and gauges and have it under about -25 hg (as low as the pump could pull it seems) will let it sit overnight and if it holds I will charge it. I did also find a leak. someone lost an o ring on the lower hose on the condenser I haven't touched that hose up to but lucky my aunt abandoned a car here not too long ago so I made use of an o ring from her car.
fingers crossed for cold ac tomorrow
Need heat here right now!! Hot in Bama??
