Hot AC air
anthony57
florida
I bought a 2002 Expedition, Ac blows barley cold air and sometimes hot air from all vents (front and rear). Where do I start troubleshooting. Already checked the low end ac port with gauge and it read freon was full.
B
bedrck46
Guest
would be very helpful if you could post the pressure readings from the low and high sides as well as the ambient temp. with the engine running also try to get the discharge temp at one of the dash outlets
B
bedrck46
Guest
was the engine running when you checked the low end port
stamp11127
Temple, Georgia
You will at the least need an a/c gauge set to start a proper diagnosis of the system. Some auto parts stores may rent them or you can get a low end set from Harbor Freight. A/C gauges read psi on the low and high sides - not empty or full.
What did you use that determined the system was "full"?
A
anthony57
florida
I used a can of EZ Chill that had a gauge attached to it. Can't remember what the psi was. Also I did not check the high end port. Wasn't sure if that was recommended.
B
bedrck46
Guest
kindly answer all the questions it will be a big help
stamp11127
Temple, Georgia
If you kept the EZ Chill can connect it back to the low side port, start engine and put on max ac. Let us know what the pressure is after a minute or two. We will also need to know what the outside temp is when your doing this.
You should still get a set of gauges for more accurate pressure readings. You can not connect the can to the high side port. That port will run from 235 up to about 425 psi. That tin can would become a bomb if you did connect it.
Why did you add refrigerant to the system? Was it low, just not cooling or was out?
B
bedrck46
Guest
stamp if he doesn't provide answers by morning then I would say we should walk away from his problem
stamp11127
Temple, Georgia
We don't know what shift he works so it is better to give him at least 24 hrs. to respond. Plus he needs time to get the reading in order to continue. Also Florida is F'n hot during the summer, he will be back....
gnorman
