Poll about 5.4l V8 and mileage
5.4l V8 and mileage
  • You are under 100k and have had major issues.
    Votes: 44 8.3%
  • You are over 100k and have had no major issues.
    Votes: 223 42.0%
  • You are over 150k miles.
    Votes: 164 30.9%
  • You are over 200k miles.
    Votes: 88 16.6%
  • You are over 300k miles.
    Votes: 12 2.3%
  • Total voters
    531
american steel
delaware
replaced my 2010 navigator 3 valve 5.4 with an aluminum big bore 5.4 block now at 352 cubic inches better airflow from head porting its a big difference. but still the 5.4 engine always lack bore size and decent airflow.
hey its a better engine than the 5.0 is I cant argue with that.
247k on my 1998 EB but that one just sits behind my shop
american steel
delaware
Wow did you have to sleeve the block
yes its an aluminum block I bought from MMR. the top end is factory. ported head and factory camshafts. short tube headers and a bigger TB stock injectors a tune was added by my tuner and a CAI.
plumcolr
freehold nj
2006 exp
Bought used replaced plugs, 4had been changed in past, so called mechanic could not get the other 4 out, I had no prob while following fords 3 valve tsb.
Trans cooler lines rusted thru at bottom of radiator where they were held together by plastic clip. They rusted under the clip, rest of lines were fine. Electrolysis?
Fighting with L f half shaft not unlocking.
Gas mileage? Don't need no steenkin gas mileage, 14mpg on a bad day, 15 on a good one.
DRS1
the bubbling of the paint its all over the lip of the hood and the tail gate and its only on those two areas hummm? wonder who else has this problem???
Everyone.... For all years gen 2. A mess. And Ford does nothing unless sued in small claims court. Imagine 6-10 years from now all those aluminum pickup trucks with galvanic corrosion all over the place.
Genesis 2012 TAU 5.0
Sent from my iPhone using Tap..
Martin Rester
East Texas
07 Expy
07 Expy EL.
just over 100K, 102235.
Just had 100k service at dealer, $$$$.
Bought just under a year ago. Great vehicle for my needs.
booboo24
marin co, california
2000 xlt 5.4 4x4, just went over 200,000 miles, original motor, trans, transfer case nothing major, just a couple popped plugs, shooting for 300k.
cdaler
CO
2001 XLT 5.4 4x4
199,500 miles- changed spark plugs at 100K big mistake, had to time sert cyl 8 7 & 6. about 3 months apart. Had the local shop retorque remaining spark plugs and no issues for last 99K miles. Will not mess with sparkplugs unless check engine light comes on. Running boards are rusting out. Oil pressure gauge is bouncing and oil pressure light blinks so going to replace the oil pressure sensor next oil change. Bought brand new and love my Epxy!
ExpyEL2015
Almost to 169,000!
My 2007 EL 4x4 Limited got to about 168,000 and the engine started "tapping." Took it in and the dealership said the engine needed to be replaced. Didn't have any problems before that. Shame to loose such a nice condition car otherwise, but I just bought a 2015 EL Platinum 4x4 and it feels great with one exception (see trackback link in this post for details: http://www.expeditionforum.com/f50/new-member-new-expy-rust-question-26693/)
edyk1986
