wingrg
Yup going to get those codes better, because i can't found any wiring diagram about advance track system in the workshop manual.
The c1998 is what I had as well. 150 bucks later from the dealership I had no more light. I tried scan tool and other enhanced scanners and I found it has to be the dealership. Even the crystler dealership that I bought it from wasn't able to do it.
i can scan and attach my invoice if that will help you any so they will know what needs to be done
I fixed my problem. I had the same issue, door locks, liftgate, auto headlights, key fob, and radio not shutting off. I found two white and red wires coming from the middle plug in to the VSM broken. The wires were in the passengers door sill about a foot from the A from/fuse box. The wires were corroded and broken. As you can see from the pics, the wire was broken. I didn't have 12 volts on pin 3 on the middle connector on the VSM. Hopefully this will fix everything.pics
