Is it worth the cost?
Hamfisted
Ft Lauderdale
For chits and giggles did you try running it with a heavier weight oil in it, like 20w-50 or straight 40w ? Sometimes that'll buy you some time. When I was a kid we had an old Ford wagon that severely overheated, to the point it needed new plug wires to run. Knocked like hell on 30w oil but some of that racing 70w oil shut it up for another couple of years ! Ended up trading it in on a new Mustang later on for the $500 trade in deal. It never did smoke, just knocked on light weight oil.
-Mike
M
MLKESQ
I did try 5-30 just because it's been so dam cold this winter but the 5-30 didn't change the clatter. I didn't want to starve the top end with too thick of oil either. While it might quiet it down ittt just covers up the issue
knewblewkorvett
Iowa
$7K :eek: Man, that seems really high. But, if that's your only choice, I'd get rid of her.
I looked up her KBB estimated private party price, only $3800 which seems really low to me. Anyhow, no way would I spend $7K on a Expedition that's worth less than $7K
M
MLKESQ
Thanks for all the comments guys. For what its worth, I didn't necessarily give up on it but I did reach the point where I could not justify the cost. With three kids, 13,11, & 9, whose activities are semi-competitive dance for the 11 year old daughter (traveling dance team), and trap shooting in 4-H for the 13 year old and the 9 year old probably wanting to start trap too, the finances of the situation dictated that a little more payment per month for a Denali XL (fits family size better) was the only logical way to go in the end given the deal I was able to make. I was able to get $4500 trade, on the Denali with its price being $2500 or so under book. The extra $100 I had to spend to have it checked out was worth it. The Denali has some warts as its 10 years old, but the fit for the family and professional life is probably a little better in the long run.
lbv150
Northeast
My '06 5.4 sounded like a diesel until I changed both VTC solenoids. Cost less than $100 for the pair and a 1/2 hour of my time.
Snag
Madras, Oregon
4500 for a trade in is pretty good for a rig that clatters, good job. I suspect they are thinking of an easier fix then priced out to you, which you can do on these rigs, sometimes.
Good luck on the new ride and keep those kids busy, thats the best thing for them
Habbibie
Is it Christmas yet?
Chicago
Half hour? Wtf took me half an hour just trying to find a long enough hex bit
lbv150
Northeast
Ah yes....that is the key tool for the job. I used a 1/4" drive torx socket ( T27 I think?) that I ground the diameter smaller with a bench grinder, then taped it on the end of an extension with a ratchet.
But after the change no more diesel rapping noise....people thought I changed the engine. The dealer said the that the cam phasers are shot and the VTC would do nothing....
M
MLKESQ
I didn't have the oil pressure to justify even that muchwork at 15 psi with 5-20
They didn't even listen to it. Got in drove it checked off features and said this is what we will give you. The bank told me 4-5k was trade range so when they gave me 4500 it started getting hard to pass up. It all boils down to taking care of it in the first 100k. My Dodge 4.7 was problem free for me. 225k on a water pump for example is pretty good. But that engine for others was very problematic too.
In the end I think mine had deeper issues as when I was chasing the misfires on 1 and 3 after plugs and coils and swapping fuel injectors around for the last month I crawled under it while it was at idle and the noises on the bottom end were pretty scary. I thinkbit may have had the 15-40 in it when I got it because the rattles started after I had it serviced with 5-20 about two weeks after I bought it in April. Only time will tell it it was the right decision.
kheidkamp
Pittsburgh PA
Does knock and rattle go away when you apply throttle? These engines are notorious for having their cam phasers go bad. Way cheaper than 7K and well worth the fix.
