JLT Oil Seperator
NASCAR Mike
Syracuse NY
I installed the JLT oil separator last night on my 17 Expy. I have one on my 2013 Mustang GT and was amazed at how much oil is collected between oil changes.
Knowing the 3.5 Ecoboost uses direct injection, the injector never washes off the intake valves with atomized gasoline so carbon buildup is inevitable.
I had to play around with the hoses so the engine cover would properly fit but it worked out well. Here are some pics of the install. As you can see the JLT rubber hoses need to run underneath the wiring harness that has the aluminum heat wrap on it.
The part number is 3016P and it is the same one used for the 2017 F150's.
NASCAR Mike
NASCAR Mike
Syracuse NY
J Ski
3.5plati
VA
There goes any and all warranty coverages...I know several people who have done this to their ecoboosts where I live and they have all been denied warranty coverage for their new vehicles. Good luck
bobmbx
This is the reason I'm holding back on doing the mod.
J Ski
3.5plati
VA
I’ll do that when my base and extended warranties are finished. Until then, proper maintenance and regular oil changes and not doggin the $hit out of her should keep her healthy
ads245
Tampa
It's an oil separator lol. It's not going to hurt your warranty unless you have a dealer that plays hardball. If that's the case and for piece of mind for all those gung-ho about losing the warranty -- if you have to bring it in for warranty work, spend the 5 min and take it off.
NASCAR Mike
NASCAR Mike
Syracuse NY
My dealer is very good. When I had my 2005 Ford Excursion with 6.0 diesel, they installed my EGR delete kit because they knew that the EGR's were killing the engines.
If I have any kind of issue, I can remove the oil separator in less than 15 minutes.
Goff69
